How to wire subwoofers
New at the car audio I have 2 12 inch svc 4ohm subs and 2 dvc 6.5 4ohm subs what's the best way to hook them up and what kind of amp should I use
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Please have a look at this instructable https://www.instructables.com/id/Install...
Bu yanıt yardımcı oldu mu?
Know a little I never got into the channel amps and I'm sure I need more then one I'm thinking about another amp I have I mono amp now for the 12s
As long you amplifier can handle 8 ohms - you should be more than fine with both subwoofers on one amp. Using 2 different amps you could have muck ups with sinc witch could cause delays on other sub.
Well the I have now is a boss 1100 riot mono so I have to get a 2 channel amp ?
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 372
