Ana içeriğe geç
The TI-84 Plus CE is a graphing calculator released in Spring 2015 by Texas Instruments. It includes a 2.8 inch color screen, USB port, apps, storage, and a 1200 mAh battery.
83 Soru Tümünü görüntüle
Why is my calculator spontaneously clearing the RAM?
Often times when I turn on my calculator or if I'm just using it in general it will glitch and say RAM clear, when I shake my calculator I can hear a clicking noise. Is there a way to fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Check your battery compartment to see if the contact is loose. It's also possible you have a loose screw which is shorting across things when you shake it around. Carefully pull off the back and then shake it to see what falls out. Make sure you don't loose it in the process! If you can't figure out what it is post an image of it here for us to see.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Brianna Castro sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 1,984
