Ana içeriğe geç
Canon FS30 is a 680,000 pixel camcorder for general filming use and photo taking capabilities, released in January 2010. Model number: FS30
4 Soru Tümünü görüntüle
How do I tighten the joystick
The joystick on my Canon FS30 camcorder is loose and needs to be replaced or tightened. I can't change the date which in return won't allow me to do anything else with the camera. Can someone please help???!!!!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi Winston. Try fiddling with the joystick some more and see if you can get it to register a few button presses so you can get by the date and time menu. Otherwise, you can take the camera apart and try and fix / replace the joystick. Try searching for a canon FS30 service manual or parts diagram online. This should help you with the repair process. The good news is that you should be able to buy parts for your camera through Canon, if the joystick has indeed failed.
Canon Parts Website
Canon has a dedicated repair parts hotline. You could literally call them, ask for a part and they'll let you buy it in the same phone call. They don't give out parts diagrams or service manuals though, but they do help you find the part you need through images and description.
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Winston sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 208
