Ana içeriğe geç
Bu dizüstü bilgisayar Eylül 2010'da piyasaya sürülmüştür. Inspiron N5030 veya Inspiron 15 model numarasıyla tanımlanır. Üst kapağının ortasında DELL logosu bulunan, sağ ve sol tuşları ayrı bir fare altlığına sahip ve bilgisayarın sağ tarafında bir disk sürücüsü bulunan tamamen siyah bir dizüstü bilgisayardır.
The computer will just not boot
Hello,
The computer will just not boot.
Tried loads of trouble shooting with some stuff found on line.
Set to boot from external USB, but it does not seem to "pick it up" and just sits there.
Could be it that the version of the Windows for booting on the USB must be a "bootable"version?
Thanks if anyone has any ideas-
G-
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
If i remember correctly it must be bootable version. If it's not bootable it will be behaving like any installer (which you must be already booted). I recommende you get a bootable windows and check connections of your ports with motherboard (if it's soldered) if it's still not detected.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
You'll need a USB that's correctly formatted, and has a bootable version of the desired operating system.
Most importantly, you'll need to ensure that your BIOs are set to boot from a USB drive.
(If you're running off a solid state drive, with Windows 10 in particular, it can be tricky to get to the BIOs menu -- fortunately, that shouldn't be an issue with the system you're using, unless an SSD was installed afterwards)
You can also diagnose certain issues and troubleshoot by using a bootable toolkit, in order to see if there's damage to the hard-drive or file system.
However, if you never see any text display on the screen during boot-up, then it's likely to have much more extensive issues than just the operating system, or hard-drive.
Best of luck.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Gail Soberman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 18
Her zaman: 818
