Ana içeriğe geç
Repair guides and support for all-in-one washer and dryer assemblies as well as stacked units.
Washer won't start on Kenmore washer
My Kenmore washer will not start. I checked the lid switch and it's working but nothing works when I use the dial. The dryer works fine. I have a Kenmore model number 417.61712510 combo washer dryer. Any ideas please?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 3
7 Yorum
Have you checked the water fill valve?
tarafından
What problems will the water fill valve cause please?
tarafından
Washer won't turn on
tarafından
Any updates? I have this problem on the same model
tarafından
Any other suggestions? Same problem here
tarafından
2 tane daha yorum göster
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Cause 1
User Control and Display Board
To determine if the user control and display board is defective, try pressing the buttons on the control panel. If some of the buttons work, but others do not work, the control and display board might need to be replaced. Additionally, if the display is not working, check the power to the user control and display board. If the user control and display board has power, but it isn’t working, replace it.
Cause 2
Timer
The timer is frequently misdiagnosed—before replacing the timer, first check all of the more commonly defective parts. To determine if the timer is defective, consult your washer’s wiring diagram and use a multimeter to test the timer for continuity.
Cause 3
Line Fuse
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I have exact same model exact problem is it won’t fill with water but acts like it will cycle through with no water. It locks and unlocks though. I’ve tested both water hoses thoroughly. Nothing is working! If I find a solution I will let you know!!
tarafından
Where in the world is the Line fuse located on this washer/dryer combo? I having the same problem today.
tarafından
Yorum Ekle
Yanıtını ekle
Bob Sommers sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 55
Her zaman: 17,299
