Battery not charging and tested stator and rectifier regulator
I desperatly need help my battery on my 1999 Suzuki gz250 isnt charging up anymore and i have no clue what it could be, i have checked the stator and rectifier regulator, the test on the stator showed not grounded and pin to pin showed 00.9 on all three pins and the rectifier showed 0, 0, 0 , 395,413,406, 0, 0, 0, 415,389,415, so everything seems to check out i also checked the stator while running it showed 50 to 60 while on choke at about 2,000 rpm, also checked fuses, and the battery is only 2 months old it worked great for awhile then all of a sudden started not charging, not sure about the previous battery when i bought the bike it was dead and looked old, im not sure what else to check, any help would be greatly appreciated
Bu iyi bir soru mu?
James Ross how did you check your rectifier and what are those values? what voltage do you get on the battery clamps with the engine running?
oldturkey03 tarafından
