Stuck on Apple logo after screen repair (iPhone 7+)
I’ve repaired several iPhone 7 Plus devices. About 50% of the time, the phone gets stuck on Apple logo after repair is done. I’ve read a few threads on this issue and there seems to a broad opinion on what may be the issue. I always thought it may be hardware issue but I am ruling that out on this most recent device.
Any other thoughts?
Bu iyi bir soru mu?
5 Yorum
Have you tried putting the old screen back on and seeing if it fully boots?
toreskey tarafından
Thank you guys! I’ve known about the home button and front camera being the cause of it but over rul d those out on this device. This was my first time hearing about he Audio IC. I’m assuming that is a board level repair
The Wizard tarafından
Hiya, I had this problem after changing a friends screen. I must of damaged it but there were no obvious signs. I had a hunch it was the proximity sensor and it was. Changed and the phone turned straight on. It would not boot with it on or off so only way to test was to buy a new one.
Hope this helps.
Have seen the problems the ic's are causing.
Get the S9, amazing phone and no problems!
Charleigh B tarafından
You need to connect your home button wire and the top camera spk wire too. With out these it will freeze in apple logo. Once you connect everything the lcd will work. If it happens after that it might be something else. Thats what happened with iphone 7.
Ash Dangol tarafından
After I changed the proximity sensor it was still acting up.
The little metal shield that covers the proximity sensor cable on the housing must of been touching metal because I found the phone has worked no problems in 3 months without that little bit of metal. Have had no complaints since.
