Ana içeriğe geç
Sony Xperia Z3, 2014 yılında piyasaya sürülen, uzun pil kullanım süresi ve dayanıklılığıyla bilinen bir Android akıllı telefondur.
The screen is detached
Hi
The display from the top is separating.
5 cm from the top and 3 cm from the left separted.
How can i fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
It's a common issue with aftermarket screens and bad adhesives.
To fix this you will need to use a combination of B7000 liquid glue and Tesa 61395 tape and let the glue cure for about 48 hours including clamping the screen down to the frame.
Unfortunately that's how it is with aftermarket replacement screens on the Z3, bad design for holding the screen down with adhesive, main reason why I don't do them anymore.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
The best solution is to replace with new one or you can do it by the help of surgical blade place some of super glue gently and put some rubber bands on let it set for couple of minutes.. and you will be sweet
Puan 1
1 Yorum:
Good answer, didn't think of that even though I've done that before.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Ahmad Kh sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 336
