Ana içeriğe geç
Samsung yazıcılar için onarım ve sökme kılavuzları.
Reset WPS Pin Manually
A hacker was able to access the WPS pin for my Samsung XPress C1860FW, connect it to a remote network and denied me permissions to reconnect and print either offline or online. Now, I cannot access the LDC touch display because I do not have permission. I paid a network specialist but he was unable to reset the WPS pin. I cannot do that without access to the LDC display. Suggestions?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum:
can you help with this
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
Hi Jennie,
You can try the master reset procedure:
1. Hold 1,2,3 on the front panel simultaneously.
2. Enter password 1934 and select OK.
3. Select "Test Routine".
4. Select "Other".
5. Select "Memory Clear".
6. Select your country, and press "Start".
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I tried this and it says not available now. I need the WPS pin for the printer.
tarafından Paylaş
Where do I find it?
tarafından Paylaş
Yorum Ekle
1) On the selection wheel, press the “Menu" icon button
2) On the numeric keypad, enter "# 1 9 3 4"
3) Press the “Menu" icon button again. The printer displays "Tech Mode".
4) On the selection wheel, press the "OK" button
Your printer is now in Tech Mode. Within this menu you can reset the printer back to factory settings a/o reset counters, and access other printer default settings.
Puan 0
Yorum Ekle
Yanıtını ekle
Jennie Johnson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 1,912
