Ana içeriğe geç
Repair guides and support for the second generation Honda Insight.
Why do the electric passenger windows quit working?
How can I fix the problem of the passenger windows when they stop working. The drivers window works fine but the other three windows suddenly stop. Is there a part that I can replace and what is making that part die?
Bu iyi bir soru mu?
Puan 0
1 Yorum
Does the drivers side switch operate the window on the passenger side?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
There are many reasons the widow wont work . It could be the regulator , the electric motor, the switch on the passenger door , the switch on the drivers door , but the most common problem is the wires in the door were they pass through the door hing . as the door opens and closes the wires flex and bend and eventually break . Your best bet is to get out your multi meter and do some testing .Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
William Salzwedel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 359
