Ana içeriğe geç
The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 Soru Tümünü görüntüle
touch screen problem when on charger
when the ipad is on a charger the touch screen does not respond correctly. When I touch the screen, the ipad reacts as if i touch another part of the screen.
The touch screen reacts correctly when the ipad is not on the charger.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Edit: Probably just an issue caused by a combination cheap wall chargers and cables.
Bu yanıt yardımcı oldu mu?
Puan 3
3 Yorum:
HI Ben, thanks for your reply. As far as I know the screen is original. You mention that this is a common issue but I did not find the same issue on the net. Should the tape be placed inside?
Why does this help, what is the cause of this issue?
tarafından
I was wrong, the issue with touch screen and fixing it with kapton / brown tape only applies to the iPad Mini model.
Are you using an original wall charger (iPad wall charger) or a good wall charger and good cable?
tarafından
I'd like to add that the touch screen assembly has probably been replaced before and that the replacement is susceptible to bad charges.
So either like @benjamen50 said: bad cable or charger and cable, OR cheap touch screen, OR all of the above.
If the touch screen has never been replaced, then the cable and possibly charger or both that your are using must be extremely bad quality to cause this issue.
tarafından
Yorum Ekle
Yanıtını ekle
hans sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 301
