My Cooler is not Turn in On (Kinect 2.0 1520)
The Kinect fan does not turn on, Kinect works normally for about 5 minutes and then turns off, then starts to turn on and off. probably due to overheating. After much research I saw that there are some solutions to similar problems, replace the thermal fuse, cut the yellow and blue fan cable or buy a new fan. my doubt is that if the kinect turns on and works normally for about 5 minutes, I can rule out that the thermal fuse is broken?
Bu iyi bir soru mu?
