Ana içeriğe geç
The PSP 3000 was released in the U.S. on the 15th of October 2008.
92 Soru Tümünü görüntüle
Orange Charge Light Stays On (Dimly)
Orange Charge Light Stays On (Dimly) on my PSP 3000.
I have tried two batteries, one at full charge one at almost no charge. Same result.
Otherwise it seems to run fine.
Is this a problem? Any way to solve it?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I tried a new power board, but the problem persisted. So what was it in the end? A loose connection, it seems, between the pad(?), the grey thing that runs from the motherboard , under the XO☐△ buttons and into the powerboard and the motherboard. When I pressed down on that cable close to the motherboard the charge light would go off. I disconnected it and reconnected it, and the problem went away. Thanks to all who read and thought about this question.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Have the exact same issue and tried disconnecting and reconnecting the power strip. The light went off at first but came back after turning psp on and then off.
tarafından
Yorum Ekle
En Yararlı Yanıt
Does it glow bright when charging? If yes then probably a short/leak but not a bad one. Should be OK, though.
Puan 1
4 Yorum:
Thanks for your reply. Yes it does, glows bright when charging and does not turn on when in standby mode. Would this be the power switch board or motherboard do you think?
tarafından
This kind of small current leak would probably happen near the power switch, although it could happen somewhere in the motherboard too but it's unlikely.
tarafından
Thanks again. Just one last thing, the same problem happens when I plug in the AC adapter without a battery! Orange light on dim, fickering a bit. Does this change your opinion? If not, I will try changing the power board before giving up. (^^)
tarafından
I would still stick with the current leak answer, although you can try changing the power board to test it out.
tarafından
Yorum Ekle
Yanıtını ekle
suaviant sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 40
Son 30 gün: 122
Her zaman: 8,081
