Ana içeriğe geç
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
Where is the intake air temperature sensor located?
My check engine light is on so I did a code check at my local parts store, the scanner said my problem is an intake air temp. sensor. My problem is I can,t find it. Please help. The reason I had it checked is because it takes me 30 min. sometimes to get it started. I've replaced fuel pump, air charged sensor, head work done, stopped the heating problem now I would like for it to start when I turn the key.
Bu iyi bir soru mu?
Puan 2
1 Yorum
trying to find IAT sensor on my BA 6cyl falcon auto
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
chadell if you are looking for the physical location of the sensor, it is on the left hand side of your engine and all 4 cyl and 1998 models have the intake air temperature sensor installed in the air cleaner housing and it is only 2 wires. Check the attached image ;-) it also helps if you give the error code that you originally got.. anyhow here you go.
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
Turkey - I realized after reading your answer that chadell may have been stating that he couldn't find it on the vehicle not that he couldn't find the part ;-)
tarafından
mayer, happens to me all the time it just shows we are all humans ;-)
tarafından
Yorum Ekle
Here you go: http://www.google.com/search?client=safa...
Puan 2
Yorum Ekle
Yanıtını ekle
chadell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 9,664
