Ana içeriğe geç
Repair guides and troubleshooting for the Dell Alienware M17x R4, the 4th iteration of the M17x Dell Alienware gaming laptop computer.
How to remove M.2 ssd.
where is m.2 located om M17 r4.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
If nothing else, download the user manual from here [http://downloads.dell.com/manuals/all-pr...|Owners manual] It includes instructions for the removal of all parts.
Update (06/01/2018)
M17 R4 SSD card is under the top cover. You have to remove the cover/touchpad/keyboard to get to it.
Check this mislabeled video for more info https://www.youtube.com/watch?v=aXzvIwaB...
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Hi, already have user manual and nothing there .
tarafından
I think there is an overall confusion right now about what model your computer is and where the SSD is. I suggest that you remove the cover of whatever model computer you have and post some pictures of what you see. That way we can at least all be on the same page.
tarafından
M17x R3 and R4 are not M17 R series.
M17x R3 and R4 have a mini pci slot (only sata2 speed) for ssd , not M2 slot
tarafından
Yorum Ekle
It sounds like you have the newer version of the system.
Here’s a good overview of the drive locations and what is needed: Inside Alienware 17 R4 – disassembly, internal photos and upgrade options
Puan 1
3 Yorum:
Hi, and thanks' for the reply.
I have the M17 R4 this is a older model. You posted the 17 R4. 17 R4 is a newer model.
tarafından
I do hate it when they reuse the same model name with a slight difference ;-{
If you have the older model then I believe your system only has a support for dual 2.5" SATA drives not M.2.
The M17x R4 model in-between this one and the one in the guide has a single mSATA M.2 bay just under the bottom cover.
tarafından
Older model yes. And it does have a M.2 ssd.
tarafından
Yorum Ekle
Try checking out the notebookcheck review of the M17 R4. Notebookcheck usually has a partial teardown in their review. In this case, there's some photos of the bottom of the laptop disassembled. Check it out here:
https://www.notebookcheck.net/Alienware-...
Puan 0
1 Yorum:
Hello, could not find anything about notebook check.
tarafından
Yorum Ekle
It is listed in the user manual I got for my M17 R4 in 2021 with an NVME m.2 and 307 graphics card. Not sure which one you got but check this out.
https://dl.dell.com/topicspdf/alienware-...
Puan 0
Yorum Ekle
Yanıtını ekle
orte7e sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 2,442
