Ana içeriğe geç
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
How to resolve F20 error code?
I have a Kenmore Elite HE3t front load washer that's giving me an F20 error code. I have replaced the flowmeter, inlet valve and pressure switch and am still getting the code. I have blown through the pressure switch tube and my water pressure is fine. I am using standard hoses. I am at a loss for what to try next.
Bu iyi bir soru mu?
Puan 2
10 Yorum
Is there’s a way to bypass the flow meter ?
tarafından
My washer works all the way to rinse and spin and won’t spin and spray water in rinse cycle. It does this on every cycle even just the rinse and spin it will run fine until spin and rinse in the last 16 minutes then throws the F20 every time. Only way to finish is to put it on rinse cycle and go straight to spin only to get the clothes dry enough for the dryer.???
tarafından
@piper7199 Did you ever find a fix? I'm currently going through the exact same thing to a tee.
tarafından
I have had three Kenmore washing machines (really whirlpools) Flash` f20. I got them for free after the owners replaced the pressure switch and pump. I have never fixed anything but I decided it would be fun to take them apart for the box of screws and to use the water pumps for my pond. I accidentally fixed two out of three washing machines by replacing the hose to the water pressure switch ($20 online for the oem part) with some 1/4 inch sprinkler drip hose I had lying around. There was just a teeny tiny hole in the hose. Walla! I am suddenly a mechanic who fixes things!
tarafından
i m experiencing the same error f 20.
i ve change the hoses and clean the hose strainer but still the same error.
did anyone solve the mystery?
Thank you in advance
tarafından
5 tane daha yorum göster
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
@dilligaff F20 means that you have a water fill problem on the washer. " If the washer is not filling when the F20 appears:
Check to see if you have Flood Safe devices on the inlet water hoses to your washer. If you do, these devices could be causing your problem. They will activate to shut off the water flow to the washer at times. I do not recommend using these devices on this type of washer.
Turn off the water valves behind the washer. Disconnect the hoses where they attach to the back of the washer. Place the ends of the hoses in a bucket and check the water pressure and volume coming from the hoses. If the flow is inadequate, you will need a plumber to correct this fill problem.
When you replaced the inlet valve did you replace the small screen filters? It is ok to leave them out for a test as well.
If the washer is filling normally when the F20 appears:
Check for a siphon problem in your drain system. This could be caused by the drain hose being installed incorrectly. The drain system requirements for this model are illustrated in the second image below. Also, make sure that the opening at the top of the stand pipe is not taped shut. Air must be able to flow through this opening. The drain hose should not be pushed down this pipe more than 8".
Check for leaks in the hoses or under the washer. A leak can prevent the washer from filling properly. You could have a problem with the water level pressure switch, the flow meter or the central control unit (electronic control board). Also, an F20 on some models of Kenmore HE3t washers indicates a problem with the heater circuit. ". Let us know the exact model number for your washer.
See if you can run the diagnostic program for your washer and what code/error you get. Kenmore-HE3T-washer-techsheet.pdf
Bu yanıt yardımcı oldu mu?
Puan 3
2 Yorum:
"Turn off the water valves behind the washer. Disconnect the hoses where they attach to the back of the washer. Place the ends of the hoses in a bucket and check the water pressure and volume coming from the hoses. If the flow is inadequate, you will need a plumber to correct this fill problem."
Why would there be pressure if the water valves are off? Did you mean to say turn them on? Or is there a missing step here to turn them on after they're in the bucket?
tarafından
Turning the water valves back "on" in order to check the inlet water flow is implied. How else are you going to know if you're getting adequate flow from the water source of you don't open the valve(s)?
Keep-in-mind that the water source must/should first be turned "off" before disconnecting the inlet hoses from the washing machine; just be near a sink (or have a bucket handy) to catch the residual water in the hoses after you loosen them at the back of the washing machine.
tarafından
Yorum Ekle
I got error F 20 and had water leaking out of the front of the washer it turned out there was a sock stuck between the seal and the drum blocking what looks like a sensor. As soon as I removed the sock the washer works great
Puan 3
1 Yorum:
Exact same fix. A sock between the seal and the drum.
tarafından
Yorum Ekle
I had the hot water valve turned off and go then F20 message. Turned it on and problem fixed!
Puan 0
1 Yorum:
Sooo I turned my hot water valve off to see if it would quit putting warm water in on cold only cycles and it tripped the f20 code does this mean the inlet valve is bad allowing to to fill with both hot and cold water?
tarafından
Yorum Ekle
Check that the water entry holes under the seal flap at the bottom center of the door opening are clean too. This fixed error F20 for me.
Puan 0
Yorum Ekle
I had this happen when I had shut off the main water and drained the pipes to do some water pipe work. Apparently there was too much air in the pipes going to the washing machine for it to get going. I disconnected the water hoses and opened the valve for a split second to help let the air out, reconnected and it is working again.
Puan 0
Yorum Ekle
Yanıtını ekle
D Gaff sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 33
Son 30 gün: 367
Her zaman: 72,405
