Ana içeriğe geç
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
My charger cable is turning yellow after battery repair
Hi,
I have just changed my battery and everything when amazing but, I have noticed over the past month and a bit that my charger has turned yellow near the connector. Everything is functioning fine. The connector when charging gets very hot within 10 min of charging.
Thanks in advance,
Liam
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
That is a symptom of overheating and the cable should be replaced. You can read more here.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
The yellow color is indicative of oxidation, i.e. it is doing a slow burn. Please post a Coconut Battery image with the mag-safe connected.
tarafından
Yorum Ekle
I wonder if there is another problem.  If the problem didn’t start till you replaced the battery, then it could be related to the battery.  Is it possible that the battery is drawing too much current?  That could explain the “slow burn” that is now occurring.  Is the new battery an Apple battery, or is it an “after-market” battery?  If it is after-market, then it could be a defective battery.
Puan 1
1 Yorum:
Hey, I got my battery replaced as well and this only started happening after for me as well
tarafından
Yorum Ekle
Yanıtını ekle
liam sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 2,951
