Ana içeriğe geç
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
141 Soru Tümünü görüntüle
trackpad wont click down at all
when i say it wont click, i mean it is tap reseponsive, it just wont click down, its been happening for about a year now and i need help. it will not click down as in i cannot drag photos or files without the help of a mouse.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Your model uses a touchpad which unlike the older trackpad does not have a mechanical clip plate. There is no means of adjustment only replacement. Here’s the IFIXIT guide you’ll need to follow: MacBook Air 11" Early 2015 Trackpad Replacement and here’s the needed part: MacBook Air 11" (Mid 2013-Early 2015) Trackpad
MacBook Air 11" (Mid 2013-Early 2015) Trackpad Görseli
Ürün
$109.99
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Actually there is an adjustment screw that you could try before replacing the trackpad, if you have the laptop open, it is at the bottom center, right below the trackpad, you can see it in the video thumbnail. It is a T5 screw. Try that first before replacing the trackpad.
Puan 0
1 Yorum:
If the trackpad does not click, how would I use the screw to adjust or fix that? Thank you.
tarafından
Yorum Ekle
Yanıtını ekle
Logan Emtman sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 879
