Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2264 Soru Tümünü görüntüle
LCD malfunctioning with a fully working touch screen glass screen
I recently dropped my iPhone 7 on the floor with the back facing the floor. When I lifted it up its shape seemed to be fully intact , it`s LCD was malfunctioning ( It seems as if the upper part of the screen is working but reflecting the lower part of the screen at the same time; there is a crack beneath the glass screen and not on the screen that can be seen when the phone gets lit up) and its glass screen was fully intact. I was able to use all the function on the phone including touch screen, camera and listening to music .
After a few inspections on my phone, I realised it is very slightly bent ( almost impossible to see). The phone`s LCD sometimes works ( the image can be perfectly seen but there are transparent lines going throw it and the crack still stays) and soemtimes doesn`t ( the upper corner of the screen has coloured lines going throw it and the weird reflection can be seen again).
What happened? How much does it cost to rapair? Shpoul I repair the phone?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like you need a screen replacement. Look over the guide and see if it’s something you think you can do yourself, otherwise you can take it to a shop and they will fix it up for you.
iPhone 7 LCD and Digitizer Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
how much would it cost for someone professional to replace it
tarafından
Alexander,
My store charges $99 USD to replace the screen on an iPhone 7, but it is going to vary greatly depending on where you are and the stores in your area.
tarafından
Yorum Ekle
Yanıtını ekle
Alexander Alexandrov sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 62
