Ana içeriğe geç
iPhone'un 5. jenerasyonu. Cihazın onarımı basittir; tornavidalar, kanırtma aletleri ve sabır gerektirir. GSM/CDMA / 16, 32 ya da 64 GB / Siyah ya da Beyaz.
2193 Soru Tümünü görüntüle
Cannot press the 4s home button after replacement
Hello guys, I am having a weird problem that is really confusing me. Changed the home button for my old iPhone 4s but when I close the screen and screw all the screws back the home button is always in pressed down state. It is not pressable at all because there is no room for movement. Don't know what went wrong. What should I do to prevent this from happening?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
Had you tried to check the microswitch itself? Try to operate phone with screen slightly lifted up - home button pads should not connect with device.
also chech if they are not dirty or shorted
Multimeter connected to button output will be also usefull for you
tarafından
Checked and the switch itself works fine, button presses easily. But when I close the screen, button immediatly gets stuck and hard to press down. There is just not enough room for the up and down movement for the home button when the phone is assembled. Weird..
tarafından
It can be that you used wrong screws to mount your elements. Chech the iFixit teardown and measure (or line them up and go from smallest ;)) those screws that you've removed. Those little differences could crack your screen or unglue plastic covers on back.
Please mind to write if you had mounted button metal cover properly. Additionally chech those metal frames that comes from LCD cover, and those "clips" inside of device.
I'm guessing now, but mess on top of frame could done some stresses that are causing your button to stuck.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Most likely this is being caused by the screen not sitting right in the mid frame. Loosen screws securing screen and make sure everything is aligned. When re-tightening do not apply pressure to either screen or mid frame. have the assembly resting on a hard surface and tighten the screws.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Elgar sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 52
