Ana içeriğe geç
Her ikisi de 2015 yılında piyasaya sürülen Dell XPS 13 dizüstü bilgisayar modelleri 9343 ve 9350 için cihaz ve onarım bilgileri.
screen blank unless at certain angles
this seems similar to the issue of most of the Mac notebooks where the screen is blank at certain angles except this is happening with a Dell XPS13 that's been faithful for the last 2-3 years. a few days ago the screen started to flicker before turning off and despite a reboot the screen didn't come back on. it wasn't until the screen was adjusted that it was determined it works at certain angles and immediately goes black at other angles. any suggestions on what to do for this?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
In my experience it is usually the cable that either hast to be re seated or replaced. If not the cable it could possible be the lcd itself. I would start with the cable.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
I've opened up the machine to verify that the cable is intact and that there are no awkward bend points. That said, I noticed the display is somewhat loose with some give before opening it past the 90 degree mark. seems like the trigger to turn off the display is getting triggered prematurely due to this... any suggestions on this particular model?
tarafından Paylaş
I would tell the pc to do nothing when the lid closes and see if that has any effect. If it is still doing the same thing i guess you would have to replace the sensor. I have never has to replace one before.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
dimm0k sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 49
Her zaman: 2,087
