Ana içeriğe geç
Repair guides and support information for televisions manufactured by RCA.
181 Soru Tümünü görüntüle
TV defaults to Analog
I have an RCA TV, model number 27V414T. It is an analog and digital TV - it came out right before everything switched to digital.
The problem is, it defaults to analog; and the only way to switch between analog and digital is with the remote. But the remote is broken.
I programmed a generic remote, so I can operate the TV that way, but it won't switch between digital and analog.
Is there a way to get it to default to digital, or am I stuck buying another remote?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I found the answer. I go into the TVs menu, and I choose to scan the channels. Right before the scan is done, it asks me whether it is digital or analog, and antenna or cable. I select digital and antenna, then exit the menu. Problem solved!
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
MrJimPhelps sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 47
Her zaman: 2,203
