Ana içeriğe geç
Model numarası A1707. Haziran 2017'de piyasaya sürülen bu MacBook Pro, 3,8 GHz'e kadar Turbo Boost destekli, 2,8 GHz dört çekirdekli Intel Core i7 işlemciye kadar Kaby Lake işlemcilerle donatılmıştır.
Left fan stuck at high speed
I spilled a little water on the keyboard and immediately dried it out. The laptop functioned perfectly fine after. I was worried that there could be some water deep inside so, a couple days later, I removed the logic board to clean underneath it. There was not any water there. I used canned air to clean out dust, and a hairdryer to make sure there was no water. After reassembling, the left fan has been stuck at full speed whenever the computer is running. I did not remove the fan during this cleaning.
I am using iStat Menus. The thermal sensors appear to be fine.
Resim
I am able to use iStat Menus to set the fan speed for the right fan but the left does not respond to the controls.
I tried resetting the SMC and PRAM. I ran an Apple Diagnostics and it said there may be a problem with the fan. I installed a replacement fan and the problem still persists.
What can I do to get the fan under control? Could the heat from the hair dryer have damaged the fan connector or its circuit?
Bu iyi bir soru mu?
Puan 3
6 Yorum
@tbertin Hello! I have same problem on my MBP 15’ 2017. How did you solve this problem?
tarafından
Hello! I have the exact same problem. The left fan stuck at 6500rpm and the right fan is fine. The left fan is also not manually controllable by the Fan control software like TF Pro. How did you solve the problem? Thank you.
tarafından
Did you ever get it repaired or looked at by a company that does component level repair?
tarafından
I did not fix it. It likely needed component level repair which was not worth the cost to me.
tarafından
has anyone solved this issue ? my A1707 has the same issue after the battery is replaced.
By the way, can I just use it with one fan spinning at full speed all the time ?
I just want to use this macbook for one more year, and then I will get a new one.
tarafından
1 tane daha yorum göster
Yorum Ekle
9 Cevap
Filtre ölçütü:
Seçilen Çözüm
I seriously doubt canned air would have damaged anything on the logic board..fact is that even if a small amount of water reached the board it might have shorted out a secondary but certainly not useless component.
Fact is that due to the size of parts it's hard to see anything with less than 10x magnifying and often one can't see anything at all and just needs to test power/data lines. If it spins full speed and a replacement fan and smc reset didn't help it's likely the fan speed control data line or related component got damaged. I'm afraid you'll need a component level repair professional here.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thank you. That makes sense.
tarafından
Yorum Ekle
Hi! I have the same issue and I found out one of my transistors, more specifically Q6050 was mising from my board. It was yanked out most probably during reassembly. (Oh yeah, and a resistor too)
Resim
As you can see the trio of black resistors and the transistor in between should be complete each fan but the one at the bottom has missing parts.
Resim
The transistor is the black block while the resistors are the silver ones with a black middle. I've ordered these parts online and I'll get back if it fixes the issue.
Puan 2
4 Yorum:
Same for me, thanks. Seems that keyboard ribbon connector cause damage to it, when left under system board.
tarafından
Could you help me understand what is MOSFET? I googled it and I see it's a chip. How do I identify it for my MacBook?
tarafından
this is ridiculous, why are macs so ridiculously touchy and purposely difficult to work on? honestly compared to lenovo they are junk. maybe the m1 is better, but if made the same they are junk. don’t defend them because it’s apple, they should be better than this. i like apple but i know they cut many corners. now do i blame them? !&&* no, because people don’t complain.
tarafından
I have a 2017 A1707 mlb 820-00928 with high fan speed only on left fan. HWMonitor not showing any high temps which doesn't suggest a sensor issue. I was thinking that it was possibly a PWM issue from damaged/missing components so I Googled and found this thread. Mine was the same issue, missing Q6000 the mosfet for left side fan. https://imgur.com/a/BQ1LDYj Two pads missing and the left hand pad had a via under it which goes to pin 19 of KBRD connector. I repaired the pads with some jumper wires see here https://imgur.com/a/zaExsx9 Thanks to the other posters for their info #righttorepair #repairnotreplace
tarafından
Yorum Ekle
I had a 2017 MacBook Pro 15" with the left fan running at full speed immediately on power-on after a repair shop bungled a battery replacement.
I checked for the broken FET and sure enough:
Resim
Using the schematic and data sheet for the DMN32D2LFB4:
Resim
I found the two drain pads:
Resim
Then using enamel wire I joined them:
Resim
Which resolved the issue by tying the speed of both fans to the speed of the right fan. I'm unsure what consequences this will have on thermal/compute performance, but my assumption is that the heat pipe can transfer a lot and the left/right fans are not tied solely to the CPU/GPU temp, but some combination.
Puan 2
2 Yorum:
I would just replace that mosfet for the left fan. I cant see any real problem with your fix but those mosfets are on heaps of Macbook logic boards but you will need a decent hot air station to remove and then refit one I suppose. Well done anyway. They usually get knocked off by a spudger when the logic board is removed prior to battery replacement on particularly A1706/07 boards. Did it myself last week and I am aware of the potential too do this :)
tarafından
@pedro147
Yeah, ideally I would, I just had to repair my mom's laptop (after a repair shop broke it replacing the battery) at 2100 the night before she had to leave so I went for speed rather than correctness of the fix:)
tarafından
Yorum Ekle
You’ll need to run the onboard diagnostics to see what it tells you. Restart your system and hold the D key. That will get you in, once you get an error code let us know. Depending on what you get you may need a new fan or you forgot to connect something.
Reference: Mac startup key combinations
Puan 1
Yorum Ekle
I already bought the missing parts but the problem is I need quite a bit of skill as well as a hot air workstation. Hopefully someone would be able to fix theirs using the info below:
Here is the fan control circuit on the board (It’s missing a MOSFET-[Part#Q6050] and a Resistor-[Part#R6051])
Resim
Here’s the location of the parts on the board
Resim
Here’s the diagram for the fan control circuit
Resim
Finally, here’s the parts that you need (They’re really tiny haha)
Resim
Puan 1
3 Yorum:
I got issue can't seem to find the location for left fan components A1707 macbook 2017
tarafından
Very lucky at the end damged component were found while i was puting A1707 togather keyborad flex which were lefted under the mainboard and pressure cased the damaged to component,reslodered same one but did not work so i have to run a jumper and worked for me
tarafından
@Syed Shah Loor right under the keyboard connector. Bottom side of PCB. You need to remove the board.
tarafından
Yorum Ekle
Görsel içeriğini görün:
Resim
Resim
Puan 1
1 Yorum:
When you removed logic board this component check it must have been lose or damdged this is on other side of the right under where you plug cable for keybaord
tarafından
Yorum Ekle
i have mid 2015 15” Macbook Pro, its right fan is showing 5700 rpm max but left one is 6156 rpm max at mac fans control app. Shouldn’t they be at same rpm? Or is it normal as default?
Puan 0
5 Yorum:
on my 2016 15" Pro Left 5927 Right 5489, seems that it is normal
tarafından
@Sergey Alright thank you!
tarafından
just recover broken MOSFET (you need a donor board, microscope (lens is not enough), and small soldering iron, if trace is broken you will need a thin wire also) and FAN control will be available again.
tarafından
Check Q6050 and Q6000 on board and resistors near too. For model A1707.
tarafından
Exactly! Thanks!
tarafından
Yorum Ekle
In A1707 the location of the mosfets is right under the keyboard connector (oposite side of PCB). In my case the components were still there, but the left fan was running at full speed all the time. Did a reflow (apply solder paste and then hot air with SMD solder station) but it did not work. So, I bridged the Drain pins of both mosfets and now both fans are controlled by the right side driver. There are test pads for the Drain pins, so solder is easy by bridging those pads.
The laptop seems to be working fine with both fans controlled together, but you can install Mac Fan Control or similar app to assign more sensors to drive the good mosfet.
Puan 0
2 Yorum:
can you upload a picture how did you made it? thx
tarafından
Can you share a picture of the work you did? Was it relatively easy?
tarafından
Yorum Ekle
I’ve had the same issues plus gradual disappearance of thunderbolt ports functionality for a couple of years. And I resolved those all just today by replacing the original ports with couple of ones from AliExpress. To be honesty, I was afraid to completely break the device, and when I booted after replacement and have still been seeing same issues, I’ve thought “at least it is alive” and go for a rest. After a couple of hours without any resetting of SMC or PRAM it shouted up the fans (silence! finally!) and gradually kick up the ports so I finally can use HDPI 4K@60Hz, full-speed external hard drives and firewire audio interface via thunderbolt. It is epic win for just a $20! \ 0 /
Puan 0
Yorum Ekle
Yanıtını ekle
Tristan Bertin sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 67
Her zaman: 8,614
