Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
2265 Soru Tümünü görüntüle
All earphones not working even though chargers do
Hello there, I have an iPhone 7, with 128 GB. I haven't been paying it much attention recently, but I think it might be failing me somehow. It has about 35 GB of memory left, but its performance has been so bad the past few days. For instance, the camera often freezes, sometimes does not take a picture although everything looks like and feels like I've snapped one, the camera lags and freezes up when I try to switch camera, the Apple Maps suddenly stopped working - everything resulted in a 'No suggestions found' and walking navigation did not work as well (but it fixed itself a few hours later when all I did was surf some sites and watched 2 predownloaded episodes of Netflix). I thought it might be a memory issue as I have been travelling and I did not have time to backup all of my photos and videos (pretty sure it's the only thing taking up 80% of the memory) and I tried to use the 'iPhone Storage' function but it often freezes up or become unresponsive or when the screen goes black it just goes back to the home screen when I unlock it again.
The biggest problem that I wish to talk about is (I mentioned the above just in case someone knows if it's linked altogether or if I probably just need to get a new one or do a hard reset or something...)
So currently, my earphones/earbuds don't work. They are the ones issued along with the iPhone itself. I have 1 that came with this iPhone 7, which only has the lightning jack as well as my older one from my iPhone 5S or 6 (can't remember) as well as the audio jack to lightning adapter that came with this iPhone 7. Both of them do not work, and instead, the audio is played from the iPhone speakers when I plug any of the earbuds in. The earbuds do work as I have just tried them on a computer. The lightning dock does work as well as I managed to charge it through the wall last night, as well as from a portable charger while I am on the go.
Currently, I have only tried restarting the iPhones and hard restarting it. Also, trying to clear the lightning dock of debris (if any), as well as tracing both my audio cables to look for any breakage of sorts, but the older cable does work as I plugged it into another audio source. Any help would be really appreciated!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 20
4 Yorum
The issue i appear to have is that on my iPhone 7 i have a home button that functions but doesn’t vibrate, this goes for anything else that is supposed to vibrate. I’m losing battery at a rapid rate to the point where i get 4 hours screen time tops out of my phone and my lightning port works for charging but not for earphones, i have restarted the device and soon after they register, i can play music for about 15 seconds and then my phone no longer recognises the headphones and reverts to using the built in speakers
tarafından
when my sisster pluged in her earbuds she could not hear anything why
tarafından
I hаd a similar іѕѕuе with my earphones.
Fіnаllу I mаnаgеd to resolve thе problem.
Follow thіѕ guide hеrе: https://bit.ly/3qrsi8w
Hope thіѕ will be helpful
tarafından
Don't click on the link above, virus total flagged it as malicious.
tarafından
Yorum Ekle
17 Cevap
Filtre ölçütü:
En Yararlı Yanıt
You have to connect lightning to iphone via bluetooth. Open Setting - Bluetooth, then you’ll see “Lightning”. Pair it, then your earpod will get connected.
Bu yanıt yardımcı oldu mu?
Puan 8
11 Yorum:
You cannot connect a lightning cable to Bluetooth. How does one connect a wire to a wireless connection? The two are not interchangeable. Please revise your answer.
tarafından
thanks for the information
tarafından
Thanks, it finally works!
tarafından
Thank you!! I would never have thought to look in the Bluetooth settings to connect to the lightning port - but it works!
tarafından
Thank you it works
tarafından
6 tane daha yorum göster
Yorum Ekle
The usual test for seeing if u have the audio ic issue is the following 2 symptoms
  • Long boot time, takes ages for the phone to start up
  • In the voice memos app on the phone u cant record a voice memo will say something along the lines of no playback devices available etc
If you have those 2 symptoms its likely u have the audio ic issue caused by the phone flexing, it is a repairable fault however requires microsoldering
If you dont have those 2 symptoms then try cleaning the port make sure the headphones or the adapter plugs cleanly inside the port should be a small gap about 1mm o so all around any more and u might have something stuck in the port :)
Puan 7
6 Yorum:
Pls help me. Everything works normally, including the microphone, except for the headphone adapter that I connected. The headphone adapter works because I tested it on other devices. The device also charges and transfers pictures normally and I have also cleaned out debris.
tarafından
Headphone adapters are very very flimsy in my opinion so I wouldn't recommend trying anything else till u try a genuine replacement adapter... cheap copy adapters stop working after software updates etc or just dont work in general
tarafından
the headphone adapters work on all other devices however, so is there anything that I can do to make it work.
tarafından
same situation. all headphones work on other devices.The port works perfectly with charger jack.I believe its a setting issue rather than hardware. If the headphones are only triggered on only when the phone detects they are inserted...that means three an error in the internal programming that routes this action. There are no audio output settings for the iPhone unfortunately . Ive taken all the same steps to no avail and apple tech seems to have no answer.
tarafından
I backed my iPhone 7 up through iTunes and then restored it after completely resetting it. Worked a treat
tarafından
1 tane daha yorum göster
Yorum Ekle
STEP 1 - Plug in the headphone adaptor. Wait 1-2 seconds, this is to allow your iPhone to recognise the new device.
STEP 2 - Turn on Bluetooth from Setting (Yes, I know it is not a Bluetooth device. Take that up with Apple).
STEP 3 - Connect the device. (it will be shown as GA or Lightning )
STEP 4 - Plug in your Headphone and Enjoy
Puan 7
5 Yorum:
ok I'm going to try this once I finish my reset...which according to other comments was probably for nothing;(
tarafından
This worked for me thanks!!
tarafından
Thanks man!! it worked for me too?
tarafından
Thank you. Worked!!
tarafından
This one really worked, Thank you so much. Sending virtual hugs as gift ??
tarafından
Yorum Ekle
Try to Restore it with iTunes with the latest software. If the problem is the same so you have to reball the Audio IC and make a jumper C12 with R1103.
Puan 3
6 Yorum:
I have no idea how to do any of those things :/
tarafından
Ohh, to restore it go on youtube and type iphone 7
tarafından
Sorry, go to youtube type iphone 7 restore with itunes tutorial and you have a lot of videos that will show you how to do it step by step (it's not a hard thing), as for the other solution it is better if you send it to a good microsoldering technican to do the job (audi ic and the jumper), i hope you can fix it only by restoring it
tarafından
Jessa from iPad rehab has an amazing tutorial on how to do this.
tarafından
Hey I bought my iPhone 8plus in July 2019 but my earphones are not working yet have never even tried using them
My back camera is not working as-well,when I try to capture a picture it shows darkness only
I tried watching most of the videos to solve my problem but nothing is helping me out.Any advice about this please because I need to listen music in earphones and I travel a lot I can’t take any picture.Please help me and thanks much
tarafından
Yorum Ekle
Sounds like the typical "audio ic" component failing on your device. It either starts with your ear speaker failing or your charging port not outputting audio. This is a repair that require someone that knows how to solder.
If you want to ship your phone out i can get you in contact with someone that has done a phenomenal job with all the work i've sent him thus far. (Touch ic, backlight filters, audio ic, etc)
Puan 2
Yorum Ekle
So I’ve got the same problem but voice recording through the app works fine. So is it something else causing the problem?
Phone charges fine, just doesn’t recognise any headphones are connected.
Puan 2
2 Yorum:
This is the same issue as mine. All works fine apart from headphone detection when plugged in.
I bought another 7 Plus for the time being but will probably send my old one off for audio IC repair.
When I do if it fixes it I will update here.
tarafından
Headphones not working the first point to check would be are u using an adapter and tested headphones is the adapter original... try another adapter and headphones copy adapters like the first copy lightning cables do just stop working after a while. Failing that try a new charging port, it doesn't matter if charging still works.
tarafından
Yorum Ekle
I have also similar issue in iphone 7. After the new update i cannot hear any phone calls even there ringtone. Youtube is working fine. You can play music from library. Headset is not working. External bluetooth headset working fine during calls.
everything fine before the update. Phone has not dropped at all. There is no any physical damage from outside. Apple store said whole unit need to replace.
i have already restore to factory setting but still not work.
Please comment below is there any-cheap way to fix
Puan 1
4 Yorum:
This is a well documented problem. Your audio IC has failed. Specifically, the solder joint has broken away from the trace on the logic board. Updates will likely surface an already existing issue.
tarafından
please help. I also have same problem with my iphone 7. phone charging normally,no derbies in port, but earphones not working when i increse the volume with button it shows volume instead of ringer help me if my charging flex is short or audio ic is faulty?
tarafından
I am facing the same issue with my Xs max, charging is working fine, but headphones are not detecting,,restored 2 times, my airpods are working fine with the mobile..
tarafından
I wondered if that wouldd be the case,interesting
@Chris Storer
tarafından
Yorum Ekle
My 7 failed after iOS 12.3 update. Was working fine prior but after update I had slow boot and no voice memo recording. The usual audio IC failure indications. Had it repaired and sorted.
also have a 7 Plus and like OP have no headphone detection but earpods and jack adapter work ok in other iPhones.
Did a very quick dock port swop, still same but wonder if I did this too quick now as was rushed. No audio IC symptoms showing up and have not read anything about the link between audio iC and headphone detection though not ruling it out.
anybody else got any suggestions?
Puan 0
4 Yorum:
If the audio IC is bad then it absolutely will not detect headphones. The audio IC is responsible for sending pulse width modulation (PWM) patterns to the CPU and other components and without that frequency, nothing works. Headphones are just the beginning.
tarafından
@ Chris Storer
thanks for that answer. It appears to be another audio IC job then for me. 3rd in about 3 weeks.
I will investigate this one further snd report bsck my findings.
Cheers
tarafından
I never heard back from you on this topic. Did you ever figure out what was wrong with your iPhone? Just curious.
tarafından
Hi, just wanted to pist an update to my previous post.
Ok, I sold the iphone with the headphone detection problem in the end.
I had another 7 with audioIC and headphone detection issue. Just come back from repairer which has fixed AudioIC problem but headphone still has issue. :(
Repairer stated it might be a circuit bias problem.
Thats all I know right now but if I can get it fixed I wlll update again.
tarafından
Yorum Ekle
Please help me i have problem similar to it not exactly same. First of all i dropped my ip8+ while it is connected to the usb lightning cable then it started to not charge. But lightning earphones work properly. I tried other usb lightning cable and it doesnt charge. Is there any chance that charger can be damaged while earphones working fine. Im confused because charging and headphone jacks are same isnt it?. Plug earphones it works(music sounds perfectly without crackling sound)and plug usb lightning cable to charge it doesnt charge.
Puan 0
Yorum Ekle
Hey there, I was just looking up this issue as well because I have just tried using my dongle and headphones and it wasn’t working either, just playing out the I phone speakers.
I didn’t want to restore the phone so I just unplugged the dongle and flipped it around and re plugged it in and then it worked, I don’t know if that helps at all or if that will be the case with the new I phone 7 headphones but good luck!
Puan 0
Yorum Ekle
Unfortunately the audio IC symptoms vary from device to device.
Puan 0
Yorum Ekle
I called apple yesterday and the Genius I talked to says he has never heard of an Audio IC issue.
Puan 0
3 Yorum:
My voice memo won’t record and my Siri can’t hear my voice…Needless to say i can’t make a call either.
tarafından
Same, I can’t make a call, nobody can hear me when someone calls, my earphones sometime work then nothing, I tried to clean my charging
Port that didn’t work either. My voice memo & Siri can’t hear me
tarafından
It's audio ic issue
tarafından
Yorum Ekle
hi, i think i’m having a similar problem. my iphone 7 can’t play audio in the lightning earphones, it just played out through the speakers. charging works tho. but i have one more problem, the microphone isn’t working. i can’t record voice memos, or make a call, and no audio when recording a video. but my iphone boots normal, not stuck at apple logo. hope this problem could be solved
Puan 0
1 Yorum:
I’ve had the same issue, what i did was by doing reset network. It helps me to be able to make a call. However the earphone issue is still there
tarafından
Yorum Ekle
I have the same issue with my phone, though only solution I have found is to use Bluetooth earphones.
Puan 0
Yorum Ekle
If your earphone don't work then you must change the audio ic. It will solve the problem.
Puan 0
Yorum Ekle
Hello,
i found a video on YouTube which shows this problem and how to repair it:
https://youtu.be/VFxS3ORQwE4
Puan 0
Yorum Ekle
Even if pluged in,the headphones need to be paired by bluetooth!The charging will work regardless!
Puan 0
1 Yorum:
My headphones won’t show up under Bluetooth what do I do?
tarafından
Yorum Ekle
Yanıtını ekle
Zi Jing sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 69
Son 30 gün: 276
Her zaman: 175,824
