Ana içeriğe geç
16 Eylül 2016'da satışa sunulmuştur. Model 1660, 1778 GSM ya da CDMA olarak 32, 128 ya da 256 GB kapasitelerinde ve Altın Gülü, altın, gümüş, siyah ve simsiyah renklerinde satılır.
After screen replacement boot loop and error 4013
After doing a screen repair on an iphone 7 it launched into the boot loop. I tried to restore on itunes which prompted the 4013 error. I then took it to a repair shop where we used an apple original screen with a new camera/speaker system and with a different battery, all of which continued to give the same error. I have run out of options and want to know if theres anything I can do!
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
En Yararlı Yanıt
error 4013 usually points to a nand issue, when trying to restore if you get the progress bar on screen under the apple logo try disconnecting the cable from the phone and plugging back in straight away
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Have you tried doing a software restore with no LCD attached, sometimes it resolves issues, once the software has been done, disconnect the battery and reconnect the LCD and front camera.
Puan 0
Yorum Ekle
It could be several issues, is the touch ID in tact ? Is the proximity sensor installed correctly? Did the device slow boot (hang on apple logo before you repaired ? And agree with above Daniel could be Nand or even a audio IC issue we are seeing lots like this at the moment
Hope that helps
Puan 0
Yorum Ekle
Yanıtını ekle
Zachary Preator sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 779
