Ana içeriğe geç
The March 2015 update of Apple's 11" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
20 Soru Tümünü görüntüle
Keyboard won’t work after boot
Hi, I spilt water on my Mac keyboard and trackpad, I took off the cover and took out the battery, no water inside so I closed it up and set it to dry with a fan for a couple hours. I tested it and the power button worked, sign in screen came up and I could use the track pad and Keyboard t put in my password, and as soon as it booted up it said it is not connected to any keyboard
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Restart the computer and hold CONTROL + COMMAND + P + R to do a PRAM reset.
The screen will go dark then come alive again. Otherwise you can buy an inexpensive MacBook Air keyboard on Amazon or Ebay.
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Thanks! I bought an external mouse and keyboard, and was able to get into my computer, I did the pram but the keyboard sill wont work, It is weird because I opened up my computer in my windows bootcamp and the trackpad and keyboard worked perfectly as they did before? any other suggestions?
tarafından
You could try updating MacOS..
tarafından
Yorum Ekle
I think I have heard this before, and the error was that it had something to do with drivers.
When turning the computer on, hold down the option key. Can you then use the keyboard??
If so, it's because when it's in the OS it uses an SPI data line, while not, it uses a USB data line mode.
This means that the SPI data line is dead, and only the USB data line is working. Even if you force it to use the USB data line by soldering two connection lines together, the OS doesn't even have the drivers. Even a simple linux recovery disk does.
If you want to, you could try to do the "repair" and then maybe find some drivers and hopefully get it to work. I don't know if it will work, but if you want to, try it.
Here's a video of how to force it into always using the USB data line:
https://www.youtube.com/watch?v=geGmC1xI...
Puan 0
Yorum Ekle
Yanıtını ekle
Nik sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 121
