Ana içeriğe geç
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Why is my car not accelerating after third gear?
My car will go fine until it gets into third gear, it seems to stop accelerating as smooth and won't go into fourth until I'm going about 50. When it finally goes into fourth gear if I try to accelerate more it will try to downshift back into third gear. I have no check engine light but the manifold has a crack (if that could effect it at all please let me know, should be getting it replaced soon -image above). My knowledge of cars ia fairly limited so any advise is helpful. Thanks!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
If the crack is in the intake manifold then yes it will .Your idle will be erratic and you will defiantly lack power. If its in the exhaust manifold then it should be casting a code for the o2 sensor and you wont be getting proper fuel mix . Any kind of exhaust leak in front of the catalytic convertor is never good and should be repaired right away . Hope this helps
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
I posted pictures of it now, is that a location where a crack can cause serious harm? Like I said I'm not mechanically inclined by any means so I'm not sure what the specific parts are called. Thank you for the information, more would be appreciated greatly.
tarafından
That crack will allow air into and out of the exhaust and skew the o2 readings . however you may also want to check the transmission fluid levels.
tarafından
Yorum Ekle
Yanıtını ekle
Dallas S sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 2,564
