How to take laptop back to factory settings
i have a Toshiba Equium L20 - 197 Laptop serial number X5036405W with Windows XP and want to takeout back to factory settings BUT can only find a restore point not a factory settings
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Obviouly some one has completely re-formated the hard drive and wiped Toshiba’s Factory Restore partition.
Just download and use the Mircosoft Product Key on the underside of the laptop or use , on the existing OS, one of the programs that finds the product key on the hard drive. Probably best to do both or find a used XP CD with a product key.
Just curious. Why do you want to do this?
Bu yanıt yardımcı oldu mu?
Lost passwords to my 2 XP Professional systems. Cannot get past log-in using "Administrator" method or in Safe Mode Command prompt.
@rickruggieri At the Welcome Screen. Press <Ctrl + Alt + Delete> twice to load the user login panel and just click "O.K."
If that doesn't work look here, fgor example:
Shut down completely and then as soon as you power the device on start pressing the f11 button. Or press and hold the f11 button and it should open prompts to factory restore it.
Will this delete any existing data?
@rickruggieri Yes it will. Backup data first.
Here's how to do a factory restore:
The drive will be wiped clean when you do the factory restore. If you don't want to do that, do not proceed.
This doesn't work Ive tried this and it just continues to open up as normal. :-(
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 49
Her zaman: 16,303
1 Yorum
Have tried the press the 0 keys this doesn't work
gill.prior tarafından
