Ana içeriğe geç
Linksys EA6900 Akıllı Wi-Fi Çift Bant Yönlendirici, cihazın arkasında üç anteni bulunan dört portlu bir kablosuz yönlendiricidir. Cihaz ayrıca veri depolama için iki adet USB (3.0 ve 2.0) portuna sahiptir.
Internet connection not working
My router is working fine but it cant get an internet connection. I've reset it multiple times
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
3 Yorum:
Hi @dgold44 ,
Has it worked OK before?
Can you connect to the internet when you are directly connected to the modem?
tarafından
Yes it works perfectly fine then sometimes at night it just completely stops working.
tarafından
Hi @dgold44 ,
Just to clarify, it is the router that loses internet connection not the modem, is this correct?
If it is the router is it still showing as connected to your computer, even though there is no internet connection?
Have you tried a different WiFi channel (change in router) just to see if it behaves the same?
Have you checked that your model router has the latest firmware installed?
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Hi Dawson,
This can be multiple things but you can try these following things:
-Make sure that the cable from the modem to the router is connected
-Reset the modem
-Try a diffrent ethernet cable from the modem to the router
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Dawson Goldsberry sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 13
Her zaman: 1,013
