Ana içeriğe geç
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
Getting hot during boot
Hi I have a 6s plus getting hot during boot right at cpu and pmic I was wondering if a screen could do this if I boot without screen it's normal temp with screen it will burn your finger as soon as boots it cools but I'm unsure if it's a short on pp gpu line the reading is 0.006 on that line qwick battery drain as well as wrecking battery's within a month of replacing
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
This might be a dumb question but have you tried the screen with the front camera and/or home button unplugged?
Either of those being faulty (causing short circuit) will cause the phone to heat up at the screen connector and CPU area.
I had a client come today that had a friend recently replaced their iPhone 6s plus screen. Phone was heating up a lot due to a short circuit and not turning on.
Turns out it was the front camera cable being partially ripped and plugged in causing a short.
Bu yanıt yardımcı oldu mu?
Puan 2
3 Yorum:
Yes I have I think it might be a short in the lcd cable but it's getting hot right over cpu not the cables very confused and I don't have another screen to test it
tarafından
Il test soon if it's cpu or pmic getting hot
tarafından
In my opinion it doesn't make much sense to get concerned about cpu or pmic if the short shows up only when the screen is connected. Unless I misunderstood your description first thing to do would be to try out a replacement screen after checking carefully that lcd and logic board connectors are in perfect conditions.
tarafından
Yorum Ekle
Yanıtını ekle
dylanrichter44 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 102
