Ana içeriğe geç
16 Eylül 2016'da piyasaya sürüldü. A1661, A1784 ve A1785 model numaralarına sahiptir. Roze altın, altın, gümüş, siyah, simsiyah ve (Product)Red renk seçenekleriyle 32, 128 veya 256 GB yapılandırmalarında mevcuttur.
Screen wont go dark
I replaced the screen. Everything works fine touch color etc. But when i am on calls the screen doesn't go dark like sleep mode and i keep accidentally ending calls while on the phone. I do not know why please help?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Your proximity sensor may not be working. If you cover the sensor when the phone is on call it should go dark, which is similar to you putting it close to your face/cheek during a call.
Open the device and check your work. It could be one of many things.
-Cable is not completely seated
-Damaged cable
-Sensor failure/defect - Good to test on another device to make sure.
- damaged pins on either board or cable
good luck
Bu yanıt yardımcı oldu mu?
Puan 4
5 Yorum:
I will try this. I’ve done many repairs before never had this happen so I had no idea why. Thank you for the help!
tarafından
You would be surprise how silly some errors may be. Sometimes I forget to connect the battery and I go into panic mode thinking the phone is compromised, haha.
tarafından
@juax if the cable is damaged what cable is it? Just the same as camera or a different cable?
tarafından
Old Post but proximity sensor isn't fitted correctly. Pain to fit correctly. No cable required.
tarafından
Yorum Ekle
Yanıtını ekle
Dalton Towe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 504
