Ana içeriğe geç
Repair guides, manuals, and troubleshooting help for a wide variety of Canon series lenses.
How to remove sand from stuck 75-300mm lens barrel?
I dropped my EOS canon rebel t6i camera in the sand while filming surf shots. I was using a 75-300mm lens that was retracted when it fell so a bunch of sand is stuck in the barrel. It's very gritty sounding and almost totally stuck- can't turn the lens easily to zoom in/out.
Is there a way I can fix this myself?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
The standard 75-300 is cheap on the used market. You can get one for ~$30-40 used in working condition, depending on where you buy it. I am making the assumption it's non-USM since the USM is generally always sold standalone due to it’s price tag. More then likely, a shop will tell you the same thing I did and will recommend a used replacement due to the cost of the cleanup and repairs. Now if this was a Canon L series it would be worth seeing if a camera shop could fix it.
Now, for a warning: Unless you're willing to write the lens off, I don't recommend removing the front glass element because of how it's mounted. I took the label off of a Canon lens I have to see if it’s easy and it isn’t. You need razor sharp hands due to how it is mounted and aligned. A paint pen and exact alignment are required. You may be okay without it professionally, but a DIY attempt is difficult without it.
Since it's such a cheap lens I wouldn't take it to a camera shop - take a shot at cleaning it yourself or replace it and sell this one for parts. Take your time, since you'll total out the lens if you break it. This video shows how to take apart the lens, but it may not be the best. However, I really can't find much that covers the non-USM lens.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Hi Coryn,
You should not use that lens while there is still sand stuck into it, it can severely damage the lens!
If you want to clean it yourself you have to take the lens apart which can be very tricky and potentially dangerous. Your best bet would probably be to take it to a repair shop and let them do it. You can also send it back to Canon themselves so they can repair it but be aware that this can take several weeks and might be expansive.
Puan 0
Yorum Ekle
Yanıtını ekle
Coryn Sandie sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 1,869
