Ana içeriğe geç
Information and repair instructions for GE Freezer
GE freezer(bottom)works fine.fridge is warm
My GE freezer(bottom)works fine.fridge is warm-took all trays out,and inside at back is a panel.took 3screws out ,pulled panel off gently.at bottom is opening,and nice cold air!
Looked at panel.had to unplug it.it has a little door that open and closes .this was shut solidxthus the fridge was not letting in cold air.
Wat do I do now?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Lucky, the little door is a damper door to allow cold air from freezer in to fresh food section. It opens and closes, this is determined by the tempature sensor. When the sensor feels to warm it’ll send voltage to the damper to open. Then to close. You could have a failed sensor or a failed damper. The problem is the back panel. I believe the back panel is nothing more that an air vent with the damper desperate from the panel. Or is the damper part of the back panel? I couldn’t tell in the parts breakdown. The back panel is no longer available. I found no other damper on this model. The sensor is part #WR55X10025. It’s under $25 and worth a try. Cross your fingers and ope all you had wrong is the sensor. Good luck.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Leave the door open and put it back together.
Puan 1
4 Yorum:
Do u mean leave the baffle open and unplugged,because this will freeze fruit.
tarafından
Please give me the model number
tarafından
GE mod.gdsz05bsas5.the z mite b a 2
tarafından
It is a 2. I thought I might be able to tell by looking at the part but I can't. Maybe @ladytech can help with this one. Here are the parts for your machine: https://www.repairclinic.com/Shop-For-Pa...
tarafından
Yorum Ekle
Yanıtını ekle
Lucky sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 97
