Ana içeriğe geç
A programmable brewing machine by Keurig. This coffee maker uses K-Cup Pods and K-Carafe Pods to brew a variety of hot and cold drinks. Model Number: K2.0-400 Serial Number: 401.0200.1410931
63 Soru Tümünü görüntüle
Cannot close cover, how do it fix it?
I opened it to insert a Kcup and now it won’t close. How can I fix it?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 11
1 Yorum
Thanks, I can make coffee now. There has to be a better permanent fix. Maybe replace a part?
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I am not sure if this is the exact model, but try this I found on YouTube:
Workaround: https://www.youtube.com/watch?v=Lenlr8zA...
Fix: https://www.youtube.com/watch?v=0Mg43v6v...
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
The workaround works great. The actual fix is too complicated for me. Lol! At least I can still use it. Thank you!
tarafından
Yorum Ekle
We were able to lift up on the cover and push down on a  black plate and it closed until we ordered a new one.   I am still searching for a repair because it was one of the better Keurig’s
Puan 1
2 Yorum:
I have the same problem and also found that pushing the bottom plate down allows me to close the Machine
tarafından
What part did you order .? I can’t seem to see what the problem is although pushing the lower plate down allows it to work I cannot figure what needs the fix obviously the unit is old enough that trying to have it repaired simply isn’t worth it
tarafından
Yorum Ekle
My kcup Is off-track how do I fix it
Puan 0
Yorum Ekle
can not get the lid to close keurig 2.0
Puan 0
Yorum Ekle
How to close the lid
Puan 0
Yorum Ekle
Yanıtını ekle
Katherine Harrington sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 88
Her zaman: 19,196
