Ana içeriğe geç
Released on November 22, 2005, the Xbox 360 wireless controller is the primary game controller for the Microsoft's Xbox 360 home video game console.
Can a broken mounting peg on an analog stick be repaired?
The right analog stick was non-functioning. Upon disassembly, I found the mounting peg for the stick to be broken in two. The base of the peg still appears to function, but can the two pieces be screwed and glued? I think a replacement would be a better option, but how? This controller was bought "modded" for rapid-fire for $60, so the replacement cost is higher than a regular wireless controller. Any ideas?
Bu iyi bir soru mu?
Puan 1
1 Yorum
Depending on the thickness of the plastic you may be able to drill holes in either part and put a metal rod/pin etc use modelmakers glue to strengthen bond? I need to see it for myself to answer properly but this has worked in the past... You need a very fine drill bit..
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
With out seeing pictures I can't tell you about gluing it. But I believe this is the replacement part you are looking for here.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Sounds like a cheap part and less hassle than my idea!
tarafından
Yorum Ekle
Yanıtını ekle
marty sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 8
Her zaman: 1,401
