Ana içeriğe geç
Üstten ve önden yüklemeli Whirlpool marka çamaşır makineleri için onarım kılavuzları ve destek.
Why I can't access diagnostic mode
I installed a new control board and machine won't go into diagnostic mode. What is next step?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
1 Yorum:
What is your model number?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Is it a top load with no dial? Cabrio? If so turn it on and unplug and wait till it goes dead “ youll be impressed how long” and then wait three minutes, take a screw driver and touch the two flat leads on the plug in together “unplugged of course” then plug it in with the lid down, open the lid for sec or two then close it, used three buttons as like 1,2,3. Press 1,then 2 then 3 in normal sorta motion three times in a row, if it has a dial and the sensing, wash done spin lights under the knob, turn it a few times left, “all the way around”then right. Right. Right. Left. Right. Not to fast not to slow, every fail try, spin left few times again.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Press each button, if you see buttons responding (like LED blink whenever you press a button), this means touch pad or buttons are working. If you became certain that all buttons are responding but unit still won t go to test mode, check door switch, if switch is OK…then it must be the control board.
Puan 0
Yorum Ekle
My whoorlpool top load washer will not go into diag mode no lights will light up only the green light inside on the control board And the pump runs constently
Puan 0
2 Yorum:
Hi @philip90310,
What is the model number of the washer?
tarafından
this was EXACT problem but then when I unplugged one of the sensors to test it on the control board i just randomly tried to put it in diagnostics mode and it worked. but I still am not sure what the problem is....according to one video it is the sensor that is bad which does make sense bc it was flashing the sensing green light and humming every 20 min for 5 min intervals
tarafından
Yorum Ekle
Yanıtını ekle
Dale Wasinger sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 8,474
