How can I fix my trackpad clicker?
I can use the trackpad to move the mouse arrow around. But when I click on the bottom part of the track pad nothing happens. Can I clean that or somehow fix this?
Bu iyi bir soru mu?
Bu iyi bir soru mu?
Sometimes a bulged battery can affect the functionality of the click button. Remove and check the battery then try the click button with the battery removed. If this is not the problem you may have to replace the top case (about $35 on ebay).
Bu yanıt yardımcı oldu mu?
Can you adjust the tension screw on the white plastic Unibody MacBooks or does one have to replace the entire top case? If the tension screw can be adjusted, what screw driver is needed.
I have a client with a trackpad that doesn't click. The battery looks to be in good shape, not bulging.
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,795
