How to correct Temperature Sensor failure
I have a Temperature Sensor failure on the cooling system test.
Can anyone help?
Bu iyi bir soru mu?
Can anyone help?
Bu iyi bir soru mu?
Try opening your Macbook bottom and check the fan and the heatsink are not clogged with dust. Since the Macbook has been around for 4/5 years a thermal paste check and replacement might be in order too. That's how you can possibly correct the temperature, you can't correct the sensor. You can use the following guide for help: MacBook Pro 13" Retina Display Late 2013 Heat Sink Replacement
Bu yanıt yardımcı oldu mu?
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 251
1 Yorum
Can you give use the error message or tell us which sensor.
DanJ tarafından
