Ana içeriğe geç
An E-Cigarette vaporizer is a device used to heat a substance, such as cannabis or tobacco, to a temperature at which it releases a vapor that can be inhaled. It is a reusable alternative to traditional smoking.
121 Soru Tümünü görüntüle
G Priv Baby Luxe Bricked, need 1.0.1 Firmware
Similar to a guy I saw on here with a T-Priv 3, I bricked my mod after doing a firmware update wrong. I require the stock firmware for a G Priv Baby Luxe in order to get my baby working again, any help would be amazing.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 6
3 Yorum
I have the same issue and in search for the stock firmware for this mod.
tarafından
Hi. I found a great place where I can get all the vaping products I need and I thought I should share it with everyone.
It’s called Vaperite. Check them out https://buff.ly/3P5BF9b
tarafından
Gwam stands for Global Wholesale and Marketing and it is an online store that bridges the gap between you and products from all around the world.
The exclusive distributor for our esteemed products <a href="https://gwam.pk/product-tag/wape/">Aroma King</a>,<a href="https://gwam.pk/product-category/pods/sm...> Smok</a>, <a href="https://gwam.pk/product-category/pods/vo...>Voopoo</a>, and <a href="https://gwam.pk/product-tag/caliburn-pri...>Caliburn</a> is Global Wholesale and Marketing (Private) Limited. It is renowned for providing the best import services in recent years and brings all varieties of pods, vapes, and energy drinks to your table in high-quality.
tarafından
Yorum Ekle
10 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Thanks to Danillo for solving this problem.
To revert your currently brick mod back to the stock firmware you need to download the Nuvoton firmware update software from Smok’s website and the original firmware bin file.
Remove the battery from your Smok device
Open Nuvoton NuMicro ISP Programming Tool 2.00
Hold the fire button on your Smok device and connect to you computer using the micro-usb cable (you have to hold the fire button during the entire process)
Once device is connected to the computer you should get a device connected notification on your computer. On the Nuvoton window click Continue and then Connect on the next screen
Click on APROM and select the stock firmware .bin file you have downloaded and ☑ the following
Click Start and your device should be fixed
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
Thanks a lot..
tarafından
Yorum Ekle
I have the same issue, I think I installed a G-Priv II 1.0.5 firmware instead and now it won't boot. is there a way to format it back to 1.0.1?
Puan 1
1 Yorum:
Do you fix your proplem i had de same issue
tarafından
Yorum Ekle
Does someone has a solution for this? Where to download the original firmware?
Puan 1
Yorum Ekle
I made the same mistake. I have emailed smoktech support. Has anyone still found any solution?
Puan 1
1 Yorum:
Apparently smok after sales service told me to install the firmware! Where the Effin Eff is the firmware? Bunch of idiots!
tarafından
Yorum Ekle
hola he cometido el mismo error que necesito la solución wtf
Puan 1
1 Yorum:
Hallo habe die original Firmware für die G-Priv Baby! Kann sie per E-Mail zukommen lassen!
tarafından
Yorum Ekle
Puan 1
15 Yorum:
please send to me edwinval.reyes@gmail.com
tarafından
can you email it to me too ?? jimilvineyard96@hotmail.com
tarafından
please send to me, please : totti953@hotmail.com
tarafından
please sent it to me yunghoe23@gmail.com
tarafından
I need it please! eduvicma@hotmail.com
tarafından
10 tane daha yorum göster
Yorum Ekle
yea, and dont forget to send it to me pls!!!!!!!!!!!!!!
yveso45@gmail.com
Puan 1
1 Yorum:
Can you plz send to me too...
Dventura517@gmail.com
tarafından
Yorum Ekle
May I have the original firmware sent to me as well please. for the gprive baby lux email to forever4lala@gmail.com
Puan 0
1 Yorum:
do you have firmware E-PRIV
tarafından
Yorum Ekle
arslanfurkan999@gmail.com
Puan 0
Yorum Ekle
Hi, pls send for me too
barthagery@gmail.com
Puan 0
Yorum Ekle
Yanıtını ekle
knroo6 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 5,784
