Ana içeriğe geç
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
299 Soru Tümünü görüntüle
98 gmc 4.3l v6 oil pan removal
i have all the bolts that i can see from the bottom of the pan, but the pans still hung up i figured it would drop sorta easy with all the bolts out but there must be some i missed. where do i go from here? take the trans out, the whole motor out?
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Tap it gently with a small rubber hammer all around the seam. There may be a gasket that's holding it in place. Use a flathead screwdriver on the end to break the seal loose. You can also use the back of your fist and bump it loose.
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Careful wit the screwdriver that you do not bend the surface for the gasket, or you will have a leaky pan.
tarafından
Yorum Ekle
Yanıtını ekle
steven boomer sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 1,621
