Ana içeriğe geç
Replacing broken screen with a titanium screen.
Hi there!
Does anybody know if I could replace the lcd screen of a 15" G4 Powerbook 1.67 GHz with one out of a 15" titanium powerbook?
Many thanks
Sascha
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Scoot Head, if you check these two links you'll find a reference for the Titanium LCD: AU Optics Corporation - PN B152W01 (works in all Titanium models). Looking at the other link, the same B152W01 is advertised for the PowerBook aluminum.
http://home.comcast.net/~macdan/tibook_d...
http://www.powerbookmedic.com/Aluminum-P...
I would be not surprised that you could swap the LCDs (of the same resolution) between the two series minus the 1.67 high resolution PB G4. I often swapped iBook G4 LCDs with iBook G3 ones
.To Sascha: if you want to know your LCD model:
- open Terminal application
- paste this line:
ioreg -lw0 | grep IODisplayEDID | sed "/[^<]*</s///" | xxd -p -r | strings -6
-hit the RETURN key
Once you have the information, search on Google to find if you can get a match with a model of Aluminum PB LCD. Good luck !!
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Hi lemeris
Following your instructions, I get the same result on both machines: LTN152W3
Does that mean they are definitely compatible?
Thanks
Sascha
tarafından
The two panels have the same model number ? So yes it should be compatible.
tarafından
Yorum Ekle
En Yararlı Yanıt
They are different parts so no, you would not be able to use the Titanium LCD for the Aluminum PowerBook.
Puan 2
1 Yorum:
Thought so, thanks for your answer!
tarafından
Yorum Ekle
Why is it I feel like a Pakled when I go to sites like this?
Puan 0
Yorum Ekle
Yanıtını ekle
redfordbertl sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 11
Her zaman: 1,479
