Ana içeriğe geç
Golf arabası markası olan Club Car Golf Cart'tan sonra bazen golf arabası veya club car olarak da adlandırılan, benzinli ve elektrikli golf arabaları için destek.
Forward/reverse lever are backwards
Hi gang, I have a 2001 Club Car DS 4 stroke gas engine. Problem is small but it irks me that I cant seem to find the solution. When the cart is in the forward position it goes backwards and vice versa..,when its in the reverse position it goes forward. A little help please...chances are this is a simple fix but I guess I’m having a brain fart and cant figure it out.
Bu iyi bir soru mu?
Puan 1
1 Yorum
That’s great looking into it now, I don’t see those studs but will explore a bit more.
Thanks a lot for your response, will keep you posted.
tarafından Paylaş
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Look at the motor. On one end of the motor (the side closest to the gearbox) the studs will be labeled S1 and S2 (for a Series cart) or F1 and F2 (for a sepex cart). Take those two cables off and swap them and your problem should be rectified
Bu yanıt yardımcı oldu mu?
Puan 2
6 Yorum:
Simple, brilliant answer.
tarafından Paylaş
I’m not sure what a sepex cart is...you do realize that I’m talking about a gas engine right?
tarafından Paylaş
sepex cart speed controller, https://www.buggiesunlimited.com/product...
tarafından Paylaş
No luck finding the two studs to swap over the cables, just dont see it. Sorry....thanks for trying though, appreciate it.
tarafından Paylaş
1 tane daha yorum göster
Yorum Ekle
The problem is someone has changed the motor. Earlier cc engines ran counter clock wise and the newer ones run clockwise hence your shifter works backwards
Puan 1
2 Yorum:
So does this reverse the gearing as well? Reverse gears should be lower than forward gears correct?
tarafından Paylaş
This seems to be the correct answer as my cart is the same way.
tarafından Paylaş
Yorum Ekle
Yanıtını ekle
Den Gauthier sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 13
Son 30 gün: 30
Her zaman: 2,576
