Ana içeriğe geç
Manufactured by Dell Inc., this is a 19 in LCD monitor / TFT active matrix with a native Resolution of 1280 x 1024 and an aspect Ratio of 5:4.
No display on my monitor when turn on
When I turn on the monitor, there is no display, but when I Turn it off and on , the display shows the desktop information image for 1 second then go off.
What is the problem with the monitor?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
I´ve seen this before, and the problem was a couple of damage capacitors.
You need to disassembly your monitor and check the power supply, looking for anything out of the ordinary, like faulty capacitors (They usually looks swollen in the top).
If you found this, check the voltage and micro-farads, look for others similar and make the change.
The values in the voltage and micro-farads must never be under the original value.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Curtis Choy sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 489
