Ana içeriğe geç
Fujifilm X20 ile ilgili her şey.
Refuses to turn on
For some reason my X20 will not simply turn on. I have charged the battery still nothing Help please
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
Have you tried pressing the play button to turn it on?
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
Hello Andrew 6, I have same problem and when I press play button it starts playing the photos but the switch is of. If I switch on it will not do anything, could it be this fuse? Thanks in advance
tarafından
Yorum Ekle
I’ve had exactly the same problem on my X20. I followed the disassembly guide and traced the fault to a blown fuse on the main board, a tiny SMD fuse in 0603 package. I believe this is rated at 2.5A. I’m going to replace it and if it works I will add a replacement guide. Hopefully there are no follow-up faults.
Update (05/14/2020)
I’ve replaced the fuse on the PCB and reassembled the camera - it is working absolutely fine now! I've added steps to the disassembly guide to show where the fuse is located.
Puan 0
1 Yorum:
Where is this fuse located? Is thid fuse easily available?
tarafından
Yorum Ekle
Yanıtını ekle
Angus sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 38
Her zaman: 1,402
