Ana içeriğe geç
The 2nd generation Kindle Paperwhite was released in late 2013. The device features a 6", 212 PPI screen, wireless capabilities, and boasts a 28-hour battery life.
Paperwhite refuses to turn on, LED blinks 4 times.
Hi, my Kindle Paperwhite suddenly stopped turning on after a full charge.
I tried resetting it (long-press power for 10, 20, 40, even up to 80 seconds) but it doesn't work.
I tried removing the battery and leaving it overnight and re-inserting. Doesn't work.
Here's the weird thing - the battery seems fine (doesn't drain overnight at 3.8V), but when it's in the device it seems to be draining quickly. The kindle isn't charging it fully even though I've left it for nearly 2 days.
When I keep the power button pressed for around 10 seconds, this happens:
https://youtu.be/VoGxAfrIzug
But nothing after.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 8
1 Yorum
Same issue here. Tried bridging some contacts on the motherboard, no luck. Anyone solved the problem or tried something new?
tarafından
Yorum Ekle
8 Cevap
Filtre ölçütü:
En Yararlı Yanıt
I’ve had this happen a few times sadly with my Paperwhite - randomly goes completely dead and gives the 4 flashing orange leds when the power button is pressed.
I have had success by simply switching the charging cable with another I had lying around. I don’t know why it works but it’s worked both times for me. I hope this will help someone else out.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I have the same issue, but I wondering if it is a problem with the new software that was downloaded. The night before it was fine and it had downloaded just prior to that? My gut tells me this could be the reason..like a glitch or something (probably so you have to purchase a new one)
Puan 1
2 Yorum:
I think the same. It's not the battery on mine. It does the same with the orange light. I'll definitely NOT purchase another kindle reader. We have 3 others all purchased at the same time. I haven't checked them out yet to see if they are all inoperable.
tarafından
hi Rhea, did you solve it?
tarafından
Yorum Ekle
Hi!
Same problem here. I was reading my Kindle and went to make coffee and eat something. When I returned, it was in standby or so I thought. Since then, it’s doing exactly what is in the video you posted.
Did you have any luck?
P.S. It’s the model DP75SDI
Puan 0
7 Yorum:
No luck, sorry! I gave up and bought a kobo. Are you the same person that commented about not having a multimeter? Which part of the world do you live in?
Long shot, but if you're in India I could ship you my old battery.
tarafından
Hi! Yes, I am the same person lol.
I'd be super grateful to you if you'd send your battery but I doubt if that would help because a guy commented on your video and said that it didn't work even when he replaced the battery. What do you think? Yes, I am from India. In Delhi.
tarafından
Yeah so if it isn't charging or turning on while connected to the charger then it's probably the same problem I had, and a battery change won't help. :/
If you still want to try with my battery, let me know, but I suggest you maybe check with Amazon if your warranty is recently elapsed.
tarafından
Thanks again, mate. But In my anger I completely demolished it hahahaha. Like, shorting it out everywhere (not the battery but the board) :D
How is the kobo compared to Kindle?
tarafından
Hahaha the joys of DIY. I had a Kobo before and I like it just because it's not a Kindle, ya know? I gifted it to my SO and it's still going strong.
I ordered a Kobo Aura off of Aliexpress and wasn't charged duty (although even with duty it's still cheaper than a Paperwhite).
So the Kobo is slightly slower than the paperwhite but I like the backlight more, and the fact that I can two-finger swipe to change intensity. Plus I can completely turn off the backlight with a dedicated button. The Kobo store is also more expensive than the kindle store but I just use Calibre to convert my existing buys. It's also unexpectedly nice to have a flush screen, feels easier to hold. Overall it's not a game-changer but I like having a rarer brand. Buy whatever is cheapest.
If you want to talk more or want the AliEx link hit me up on twitter @ my same username here.
tarafından
2 tane daha yorum göster
Yorum Ekle
I have the same issue.
I took the Kindle appart and desoldered the shields and I think it is a short in the processor (MCIMX6L8DVN10AB)
Puan 0
2 Yorum:
Hey Jonas, did that fix the issue? Which one of the shields houses the processor? I can see 4; guessing it's either #1 or #2?
tarafından
Yorum Ekle
I have Kindle Paperwhite 7th Gen running for last 5.5 yrs. And I had exactly the same problem as shown in the youtube video posted.
I opened the kindle, knowing ultimately I may have to throw it. When nothing worked after spending hours I tried a weird thing - took a small piece of metal and touched across the inside housings etc. suddenly all lights switched on and it started to reboot. It worked for me, and may work for some other as well - so I thought to post. By no means it is a professional advice.
I do not the know the reason why this happened but I got it fixed a weird way.
I would suggest to not let your kindle drain completely - atleast this is what happened for my device so I guess not letting it drain completely will keep it safe for longer.
Puan 0
1 Yorum:
Where did you touch? Do you have any pic (or can you mark the area in a random picture of the kindle's insides?) I'm having this kind of problem (even with a new battery that has even larger charge capacity) and I'm seriously considering trying what you just said.
tarafından
Yorum Ekle
uhm so well, this is for you guys who still searching for the answer. I tried all the ways to fix like change the battery, use the adb command, hit the power button as hard as I can. Then, I plug the cable, in the right of the number 2 shields house of processer, find the CR500 area and hit all of that three-point by metal for seconds. The kindle will light up and show the battery-warn icon. Keep it for a while (I don’t know but I did that), then unplug, press the button and keep it till the kindle start. Goodluck guys.
Puan 0
1 Yorum:
Where exactly is that area on the mainboard? Do you have an indication or picture for it?
tarafından
Yorum Ekle
hi, anyone solved the problem? might it be a software update? i have a Kindle 2020, bought Apr 2021, so it has to work…
Puan 0
Yorum Ekle
First things first.
The operating system is running on $100.
Things are probably not immediate.
Most of these suggestions miss the point.
The amber LED light on the bottom indicates that the device
has not received enough power to load the operating system.
Once it is green then we can assume more about the state of the device.
I hate being impulsive too.
Puan 0
Yorum Ekle
Yanıtını ekle
Abhijit Shylanath sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 26
Son 30 gün: 146
Her zaman: 32,233
