Ana içeriğe geç
Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
678 Soru Tümünü görüntüle
iPhone 8 Plus touches go crazy (ghost or no) after screen replacement
I have iPhone 8 Plus with broken screen. Have changed it to eTradeSupply screen, after one day the screen gone crazy - there is no touches at times, ghost touches at times, sometime all is good. Original broken (glass) screen was working good. I have tried hard reset and etc. Obvious advice everywhere is to change screen to another one, however there is a little twist -> the screen is perfectly working with out any problems if you open the phone (so the screen part is not closed/connected with the rest of the phone), looks like the flex cable might be a problem (bending?) or is anything else may cause that? Any thoughts?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
Check the enclosure for bends. If the screen works perfectly with the phone open, it could be that there’s a bend or dent somewhere in the housing that’s putting undue pressure on the digitizer glass. also ensure that the flex cables aren’t getting kinked when the phone is closed. I have seen this happen before and it is almost always one of those two things happening.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
Alexey Demidov sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 4,700
