Ana içeriğe geç
The Dell Latitude 7350 hybrid laptop (model number: Latitude 7350) is a 2-in-1 device that functions as both a laptop and tablet. Released in 2015, the Latitude 7350 is no longer being produced. You can find repair guides and device information here.
My battery not charging
After five hours of consistent charging my battery has life has decreased significantly.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
2 Cevap
Filtre ölçütü:
It is best to make sure the simple tasks are performed first.
Check all connections when plugging in the device. Make sure your outlet is functional by using appropriate electrical testing equipment or plugging something like a fan or hair dryer in to test functionality.
Next, double check connections all the way to the unit. Sometimes the charge cord can fail and cause an incomplete connection.
Next you will want to check to see if there is any battery status when the computer is on and the charge cord is plugged in. Sometimes a failed battery will show that it is charging but the battery itself is defective. If the battery seem like it is charging, but discharges quickly after disconnecting charger, then you will need to replace the battery.
The process is of easy nature and requires that you remove the backplate of your unit.
There is a repair guide listed on the device page for the Dell Latitude 7350. There you will find detailed steps and pictures to help you replace the battery.
As always, take caution in your attempt to solve your issue.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
I had the EXACT same problem on the same laptop/2 in 1. All I did was power it off (using the power button). And turned it back on. Tip: If you wanna check your battery percentage just go to the taskbar settings and add the battery.
If that doesn’t work try restarting your computer.
Puan 0
Yorum Ekle
Yanıtını ekle
Ahmed sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 1,796
