Ana içeriğe geç
The Canon PowerShot A720 IS is a point-and-shoot camera with 8.0 megapixel resolution and a 6x optical zoom.
Will not hold time and date
When I switch the camera on, the set time and date message comes on the screen. This has to be set before the message clears from the screen. The next time the camera on you have to go through the same procedure again.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I have a similar camera (A570 IS) and mine has a second type of battery right beside the two main AA ones. It’s under a cover marked “CR1220” which refers to the type of that second battery. Pull that cover up, replace the CR1220 (or whatever battery type your camera has) and that should fix the problem.
Bu yanıt yardımcı oldu mu?
Puan 4
2 Yorum:
i tried that and it didn;t work
tarafından
@williams679 what make and model camera? what were the issues and what did you try?
tarafından
Yorum Ekle
En Yararlı Yanıt
If the battery level drops to low, a board will lose its memory. Replace the battery.
Puan 4
1 Yorum:
I have already replaced the batteries but problem still exists.
tarafından
Yorum Ekle
Yanıtını ekle
rogerdeans sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 983
