Ana içeriğe geç
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
Engine not going over 1000 RPM and falls back down
Engine not going over 1500 RPM and falls back down while my leg is still on the pedal and transmission is in park and the car’s not moving. What it might be? Transmission issue? Engine? Thanks in advance!
Bu iyi bir soru mu?
Puan 0
1 Yorum
have you had the codes read?
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@tillhimself
does the engine ever go over the 1500RPM even if the transmission is in park or neutral? This does not sound like a transmission issue but either a fuel or sensor issues. I’d check things like bad crank shaft, cam shaft position sensor, MAF as well as a throttle position sensor. It is of course also possible that your car is in limp mode. You need to give us more information as to how long this has been going on and if there was anything that preceeded this. You also should consider having the OBD scanned to see which codes you are getting.
Disconnect the battery and wait for 15-30 min then reconnect. (make sure you have your radio code if your radio requires one)See if that changes anything.
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
It's happen after replacing new crankshaft position sensor
Puan 0
Yorum Ekle
Yanıtını ekle
Sergio sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 1,908
