Ana içeriğe geç
Released December 2012, identified by model SPH-L300.This Android phone holds 4G LTE data, a memory card slot, 5-megapixel main camera, front camera and Samsung's S-Beam for fast file transfers.
Samsung Galaxy S5 G900F
Galaxy is not in the menu this refers too: Samsung Galaxy S5 G900F
When the phone is switched on, the start up logo sits there the phone does not boot up?
I cannot gain access to the phone, no matter what I connect the phone too, (i.e. Kies, Smart switch?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
This is usually caused by either one of the following:
* System software getting corrupted, can be caused by a system update, not enough space on phone or for no apparent reason.
  • Power management chip going faulty (This requires micro-soldering board level repair to fix)
  • eMMC chip (Flash memory / a.k.a hard drive) going faulty (This requires either getting the flash memory chip replaced or reprogrammed by a JTAG (flashing box, again like board-level repair).
If you are lucky sometimes this can be fixed by reflashing the System Software (Firmware) on the phone.
Here is a link on how to reflash firmware on Samsung devices:
http://updato.com/how-to/how-to-install-...
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Thanks for your reply Ben.
I tried using Odin but it failed “error” no pit file. I next used smartbox got pit file tried to flash phone still no luck. It must as you said be an electronic fault. I need info from the phone but I can't access it.
I'll have to take it to a reputable phone service to be repaired if it can be!
Thanks once again for insight!
Puan 0
Yorum Ekle
Yanıtını ekle
John Banks sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 412
